lacofdfireman
May 29, 2014Explorer
I believe it was the fan motor. Basically you can hear it click on when I switch it to cool but it's not pushing any air. The repairman said that it was showing it was using like 7amps or something like that and that it should be under 2.5amps or something like that and that ones compressor motor was showing around 9amps. The rear one that is actually working correctly he showed me the amps and it was like 1.9 with the compressor motor at like 9 amps.. The rear one cools nicely. Even with the front one when you put it on fan on high it will run for about 2 minutes then the fan will shut down. He told me it shuts down to keep from burning up the unit. Kinda a fail safe so to speak. I don't really know how to check stuff myself. I just have to take peoples advice... I appreciate all of yours.. I agree that is seems way to new to go bad. Especially considering that it probably has less than 100hrs on it. He said the bearings he thinks are bad...
