dougrainer
Aug 28, 2018Nomad
mike brez wrote:
It looks to be silver soldered,brazed.
Should it be evacuated?
I had my commercial ice machine re charged last year and they dumped whatever was in it and put new in without evacuating.
The tag on ice machine says to use only r502 not shure what's in it now.
1. Should it be evacuated? YES
2. What good will it do you if you do not find and fix the leak? Unless you are positive the Soldered Schrader valve is not leaking, if there is another leak, and it does not take long for 16oz to leak down to the point there is no cooling, you will be wasting time and money. Doug
