mike_brez's avatar
mike_brez
Dometic roof top ac
Can anyone lead me to any info on how much refrigerant a 1998 Domenic 13.5 btu roof top ac is suppose to have?
  • It looks to be silver soldered,brazed.
    Should it be evacuated?
    I had my commercial ice machine re charged last year and they dumped whatever was in it and put new in without evacuating.
    The tag on ice machine says to use only r502 not shure what's in it now.
  • mike brez wrote:
    Allready has a port on low side
    soldered or a clamp on tap? Doug
  • STBRetired wrote:
    You can silver solder on charge ports. Getting you hands on 1 pound of R-22 will be the hard part.
    Looks like flea bay has some 15oz cans for around $50 also some 35oz cans
    I'm going to call my buddy up when he gets back from vacation. He owns a small ac company and I'm shure he has a big 20er
  • You can silver solder on charge ports. Getting you hands on 1 pound of R-22 will be the hard part.
  • There is no usable charge port so how much is in there is likely a moot point.
  • mike brez wrote:
    dougrainer wrote:
    About 16 oz. If you can still read it, the data plate will also tell you. (Freon 22) Doug
    Found my old manual 16.0 to 16.5 oz
    Ok thanks nothing left on anything inside unit
    Going to need a port installed as well
  • About 16 oz. If you can still read it, the data plate will also tell you. (Freon 22) Doug
