ncrowley wrote:
When I took my Freightliner class, he recommend 10 pounds over the pressure you needed for the heavier side (use 4 cover weighing). That will make sure you OK if you put a little more in the coach. You can go to any of the Escapees locations to have the 4 corner weighing done.
10 pounds extra PSI makes a huge negative difference to comfort on my coach. I'd do everything in my power to try and get the four corners plus tag and get the proper weights for each axle. In my case, I'm already at the lower limit of weight for my chosen PSI rating so I can add hundreds of pounds of cargo without going to the next bracket.
