- msmith1199Explorer II
wallynm wrote:
The poster stated the step would hit the curb. If that is the case it can not extend and be available for use.msmith1199 wrote:
wallynm wrote:
In that case I would turn the external step off,it would not extend and open the door.Big Katuna wrote:
the silverback wrote:
Why do most or at least a lot of DP's only have two steps at the door. I see a lot of them with 2 steps and a portable third step. Doesn't make sense to me.
Rereading your post, if I had another step it would hit the curb when parked on the side of the road.
And then somebody opens the door and doesn't look down and ends up flat on their face. I don't know about others, but my DP doesn't even have an on-off switch. It stays on all the time. I have a switch that in one position the steps come in and out when you open or close the door, and in the other position the steps stay down once the ignition is off.
He said that's why he doesn't have a third step. I was also pointing out the steps generally don't have an off switch. - Mr_Mark1ExplorerOn our '08 Dynasty, we had two steps that went out with 3 steps on the inside. I have, on occasion, hit the steps on a curb and rubbed them along the ground as some sites can be unlevel.
We carry a portable platform that is about 2 inches tall with the legs in or about 5-6 inches high with the legs folded out making a taller step. Sometimes that extra step comes in handy.
Our new coach has no steps on the outside which I'm really glad. The door is set low in the chassis so all the steps are in the inside. Four steps to the driver area and 3 more steps to the living room.
I still have the portable step just in case it's needed. But, no more bumping the steps, rubbing them on the ground or them getting dirty and not closing all the way.
MM. - wallynmExplorerThe poster stated the step would hit the curb. If that is the case it can not extend and be available for use.
And then somebody opens the door and doesn't look down and ends up flat on their face. I don't know about others, but my DP doesn't even have an on-off switch. It stays on all the time. I have a switch that in one position the steps come in and out when you open or close the door, and in the other position the steps stay down once the ignition is off. - gemertExplorerWhen the air is dumped on my beaver the one and only step is often way less than an inch above the surface when extended. Depends on your MH.
And then somebody opens the door and doesn't look down and ends up flat on their face. I don't know about others, but my DP doesn't even have an on-off switch. It stays on all the time. I have a switch that in one position the steps come in and out when you open or close the door, and in the other position the steps stay down once the ignition is off. - wallynmExplorerIn that case I would turn the external step off,it would not extend and open the door.
Rereading your post, if I had another step it would hit the curb when parked on the side of the road. - Big_KatunaExplorer II
Rereading your post, if I had another step it would hit the curb when parked on the side of the road. - wallynmExplorerHow many do you want?
Why do most or at least a lot of DP's only have two steps at the door. I see a lot of them with 2 steps and a portable third step. Doesn't make sense to me. - Executive45Explorer IIIOnce leveled, my bottom step is only a few inches off the ground....I have two so a third one would end up a few inches underground.....Dennis
- doxiemom11Explorer IIWhen they let the air out of the airbags, the frame of the motorhome is closer to the ground than a gas one or a fifth wheel.
38,778 PostsLatest Activity: Jun 10, 2026
