Doug and Cassi Glass wrote:
Try lubing the arms especially at the hinge point. Mine did the same thing and a bit of silicone spray did the trick. Mine also appeared to be extended just a hair too far and seemed to lock the hinge. The little bit of dryness caused the resistance described in previous post.
Had the same problem with the coach we just got. The dealer adjusted the limit controls and it was better but would intermittently not retract. I sprayed all the hinged areas liberally with silicone spray and it now works fine.
