- D_E_BishopExplorerIf Winnebago Inds. are still using TriMark, there are instructions online for replacing it in kind.
- roam1Explorer
Yankee Clipper wrote:
My advice is to replace it before the internal mechanism fails, which will require you to drill the lock assembly out. I had to do this on my old rig, and it was something of a PITA. Fortunately, America's Funniest Home Videos was not there to watch me crawling in through the driver's door that had been turned as a seat...
been there, done that!
When that spring loaded pot metal bolt breaks, it's like cracking a safe! And as you mention, the gymnastics involved in entering the rv via open window - BlutoyzExplorerI only use the deadbolt on mine
- Yankee_ClipperExplorerMy advice is to replace it before the internal mechanism fails, which will require you to drill the lock assembly out. I had to do this on my old rig, and it was something of a PITA. Fortunately, America's Funniest Home Videos was not there to watch me crawling in through the driver's door that had been turned as a seat...
- MrWizardModeratori think 3 screws from the inside hold the it together
they are easy to replace
38,774 PostsLatest Activity: Apr 26, 2026
