- antsinmypantsExplorerThank you for your comeback, I have to go take the handle off to make sure there's no light in it. If there's no light in there all I need to do is put a lead light inside handle against end of clear tube for it to light up the handle is that correct? Looking at the pictures that's what I made out.
thank you everone - TrackrigExplorer III'd be really surprised if it doesn't have a light in it - that it's just not working. Have you had the MH since it was new? I'd take the handle off to see if there's a small LED bulb in one end of it.
Does your MH also have a similar handle on the right just inside of the door? Is it lit? Our MH also has a similar lit handle in the bathroom. They all used the same bulb.
I've had to change the bulbs in all of them. If you have a lit handle and bulb is just burned, check the suppliers the others recommended. If they don't have them, send me a PM and I'll dig through our receipts to see who we bought them from on the internet.
Bill - johnsonbertExplorerTry a place called Northwest RV supply, they have replacement lights for those clicky. They have replacement lights and also some of the Lucite handles if yours is heat checking. Hope this may help, Happy Trails Bert
- et2Explorer
antsinmypants wrote:
Is there a kit to light up the clear door handle tube.
http://www.campingworld.com/search/index.cfm?Ntt=Lighted+door+handle&N=0&Ntx=mode+matchallpartial&Ntk=primary&Nty=1&Ntpc=1
Shouldn't be too hard to wire and put a switch in. Camping world can do it if you have one close by.
