Monaramblee
May 24, 2020Explorer
bjbear wrote:Monaramblee wrote:
Holiday rambler monaco. The door opens easily from the inside but from the outside i have to pull hard on the handle. Ive lubricated everything, its not the door sticking as it opens easily from the inside.
Any ideas would be appreciated.
Take a look at: http://www.visualsc.com/monaco_door_adjust.pdf. It has a lot of info about the door handles on Monaco Family Coaches.
Usually, if the handle has to be pulled farther than normal, it is either the bushing or the rod adjustment. The bushing is the first place to look. If left as is, so that you have to pull real hard on the door handle to open, it will result in a broken handle and you will have to replace it. Will also leave you locked out of your coach. Happened to me!!!
That linc was quite informative
Thankyou....
