Monaramblee
Jun 22, 2020Explorer
bjbear wrote:Monaramblee wrote:
If the inside handle easily opens both latches does that rule out adjustment? Isnt the long rod operated by both the inside and outside handles? The outside handle willopen both latches if i jerk the handle hard.....
You would think so, but the inside handle has a larger range of movement than the outside. That means that the door will stop working sooner with the outside handle while the inside will still function.
Thank you for that info it makes sense. Now if i can get the inside handle cover off i will be in business.
