I have a 1994 Georgie Boy Swinger, owned since new. Have about 235000 miles on the odometer. The door hinge spacers are badly worn and the door has sunk relative to the door frame. This makes openi...
I have a 1996 GB Swinger and had the same problem, I fixed it as mountainare described. I used copper washers cut slightly smaller than the pin lifted the door and inserted the washer around the pin, then squeezed them tight around the pins with pliers.
