dave_330's avatar
dave_330
Door locks will not unlock
2009 Monaco Knight, The top and bottom locks will not open from the out side handle. The adjustment rod has to mush slop in it and will not tighten. The locks work fine from the inside any thoughts
  • The outside handle is probably worn, mine is in the same condition and I will have to replace it when I get home. I replaced the intermediate assembly last summer and could tell that the outside was not far behind. I would guess the top or bottom pivot on the pull handle is worn and that makes it so the tab inside doesn't push the rod up far enough to release the catches. You might check NWRVsupply.com to see if they have one. Hope this may help. Happy Trails Bert
