purplekeenah
Jan 19, 2018Explorer
I had similar issues with my fridge. If I recall correctly, there are two or three screws holding the top hinge in position. Remove the screws and hinge which will allow you to lift the door off of the bottom hinge pin. I bought some plastic/nylon discs at Lowe's that fit over the hinge pin on the bottom hinge. I think an 1/8" thk. disc took care of my problem, hopefully this will work for you also.
38,769 PostsLatest Activity: Dec 31, 2014
