MagillaGorilla's avatar
Sep 17, 2018
Door size
Why do they make the doors so small? If I have to change any furniture or appliances, I have to remove a windshield?
  • Dutch_12078 wrote:
    I removed our failing Norcold fridge and installed a residential fridge, moving them all through the coach entry door. It was close, but they fit without removing fridge or coach doors. On our previous coach, I removed a jack knife sofa without disassembling it through the door and replaced it with a residential rocker/recliner brought in through the door. What are you planning on replacing?
    I tried to remove a chair. It was a barrel style living room chair. I pulled the very heavy swivel stand off and it was still to big to fit out the door. The chair was in perfect condition but was not needed for how we use the RV. I ended up having to saw it in half. I felt bad for wasting a nice chair but found no other way to get it out.
  • I removed our failing Norcold fridge and installed a residential fridge, moving them all through the coach entry door. It was close, but they fit without removing fridge or coach doors. On our previous coach, I removed a jack knife sofa without disassembling it through the door and replaced it with a residential rocker/recliner brought in through the door. What are you planning on replacing?
  • While recently shopping, we did see some brands/models with larger doors. Talking about units less than 35'.
