D_E_Bishop
Jul 14, 2018Explorer
Might help to know what brand of steps,model and year.
If they are Kwikee, check the ground, fuses and the on/off switch.
If all is okay, as per Dougrainer, with the engine running, have someone close the door as you tap the motor. If it starts operating, you have found the problem.
Click on the following,Click here.
Use common sense and keep fingers out of the mechinism and your body free of step travel.
You need to disconnect the two wire cord to the motor and remove the three bolts that hold the motor to the gearbox and linkage. Easy to R&R.
If you download the step operators manual, it will give you lots of info. Need the series number and year of manufacture to get the right manual.
