Gjac
Jul 27, 2018Explorer III
What year is your MH? If too old you may not find a replacement controller. If you take the cover off the controller and slide the board out, you will see a couple of relays inside. Look for melted plastic on the case of the relay, that is the one that needs to be replaced. If you have good soldering skills or know someone that has it can be replaced for less than $4.
