rjstractor wrote:
The engine and transmission in my E450 based motorhome were exactly the same as those in the same year F250/350 pickups.
Hmmm ... are you sure?
I assumed/thought/hoped that when I bought our 2005 E450 dually V10 motorhome that I was getting the same chassis - engine (except for 2-valves per cylinder instead of 3 valves per cylinder), transmission, tranmission cooling system capacity, differential ring gear diameter, differential gear ratio, drive shaft diameter, brake swept area, front/rear sway bar size, rear leaf springs count/size/thickness, front coil springs thickness, rear/front shock absorber damping rates, front steering shock absorber damping rate, frame steel thickness, etc. - as was under a Ford 2005 F450 pickup truck.
And I assumed/thought/hoped ... that at least some of those things would be rated for heavier duty service than what those same things were rated for on the same year F350 dually pickup. In other words, I thought I was getting the chassis of at least a 1 1/4 ton rated truck for that year. :h
