pianotuna wrote:
A 10,000-pound increase in GVW or GCW will increase fuel consumption by about 8.5% (0.55 MPG) and is equivalent to a loss of 80 engine horsepower at 45 MPH (8 HP / 1,000 lb @ 45 MPH) on a 6% grade.
Some facts to consider:
• Proper tire inflation pressure is important for your safety and that of others. Maintaining correct inflation pressure based on the actual tire load will also optimize tire life, vehicle ride quality, and fuel economy. With a tire pressure 10 psi lower than the manufacturer’s recommendation for the weight, fuel economy will drop 0.5%.
• All tires are least fuel-efficient when new. As the new tire wears, the rolling resistance decreases and fuel economy improves.
• Most of the fuel economy advantage is obtained when the tread is 50% worn.
To a point I can agree and relate to what I put in bold in your post.
I bought a new set of Michlens the LTX's same size as the factory size on an 03 Tahoe I had , I lost 1.5 miles per gallon. I drove the same 500 miles per week, so I knew what I was getting , then got with the new tires ok I'll agree with you.
Along the route I drove there was two sections of the mile markers to
check you OD 1-6 miles I was within 2-4 feet of the markers, so I knew the OD was registering the miles correctly.
Next you say that the tires worn at 50% gets the most advantage of MPG ?
Well could it be that now the diameter of the tire is now smaller therefore the speedo/OD is now off racking up the miles faster therefore making it seem your getting better mpg ?
I sold the Tahoe with 10K on the tires so never got the tires worn down enough.
Just thinking outside the box ;)
