Blaster_Man
Feb 10, 2014Explorer
JetAonly wrote:
Good list!
The only thing I 'd add as an observation is that I typically use block heaters below 40F. I know the manufacturers don't require it, but I like the ease with which they start. Minimum block heater time I use is 4 hours. If temps are below freezing I also use the engine heat function of the Aqua Hot. Typically, when planning a cold start I will use both all night. Doing this an I see 100F on the coolant temp in a few minutes.
Same here. When the engine block heater has been on prior to start, the "wait to start" light does not even come on since the coolant temp is always over 100 degrees.
38,766 PostsLatest Activity: Jan 10, 2026
