supercub wrote:
If you use the dump switch to dump your air......and don't use the jacks, such as when you store it, and don't put the jacks down. When you start the engine, do your airbags inflate ?? or do you have to hit the retract all button on the jacks, even though the jacks aren't down?
Back to the original question. If you move the lever to dump the air bags you must return it to the right/auto position to get the bags to fill. If you leave the lever to the left position the bags will not fill. The air for the brakes will fill but not the bags.
Bill
