FloridaRosebud's avatar
Dec 06, 2019
DP lengths and Tag Axles
So, sorry if this is a stupid question, but it won't be my first, nor my last. So at what point does a DP NEED to have a tag axle? I've been told after 40', but I don't know that for sure. We're at Disney and riding around on their DPs, and they are all single rear axle DP. Then a tour bus pulls up and it's a few feet longer but has a tag. Is there a "rule" or is it just about the weight?
Al
  • Ivylog wrote:
    CA Traveler wrote:
    Axles are weight limited which is the main factor.
    Until around 2002 most DPs could carry the necessary weight on a single rear axle. That’s when multiple slides, tile floors, bigger engines and trannies push the weight over 20,000 lbs and a 10K tag axle was added.
    Up until 2012 the weight limit was 20,000 lbs on a single axle but a highway bill changed it to 23K for buses and RVs making it possible to have 42’ DPs on a single rear axle.
    Once you’ve on the tag axle, you’ll never go back to a non-tag because of the vastly improved handling and almost unlimited CCC.
    There are some exceptions to that 23,000 lb limit. As an example, The Pennsylvania turnpike has a one axle limit of 22,400lb. And they will turn you back for very minor infractions.
    Richard
  • chuckftboy wrote:
    There are plenty of 41 foot motorhomes aroumd that don't have a tag, larger are generally tags. Buses don't generally have a lot of weight other than people and if they are locally used there isn't much need to have a tag so I could imagine there are some pretty long single axle buses out ther.e
    No weight other than people? LOL. 10 tons is a big load for a single axle truck. Most would be overloaded on the back axle with 6-8 tons. And I bet for the same length bus will be heavier than the truck. In today's America, pick 10 adults at random, you are over a ton. And I would be surprised if you sample came out of average adult bus riders 8 didn't break the ton. Then add their luggage. And unlike freight, people can't be stacked high in the nose to reduce weight on the rear.
  • There are plenty of 41 foot motorhomes aroumd that don't have a tag, larger are generally tags. Buses don't generally have a lot of weight other than people and if they are locally used there isn't much need to have a tag so I could imagine there are some pretty long single axle buses out ther.e
  • Ivylog's avatar
    Ivylog
    Explorer III
  • No real rule on what length needs a tag. My 40 is non tag and my friends 38 is tag
  • In California a tag axle (total three) limits your maximum legal speed to 55.
