The other problem, which has been mentioned briefly a couple of times, is that a gas motor will have to rev much higher to get up that same hill as a DP. That is one reason why oil change intervals are more frequent with gas engines. They have to work harder to accomplish the same thing. Generally this is not a problem if you do good maintenance and the gas engine has lower miles. That same gas engine, as the miles begin to accumulate might need major work much sooner than a diesel engine.
In addition, as has been mentioned, most gas chassis start out much shorter and need to be extended to accommodate larger coaches. The chassis/gas combo was designed and rated for the shorter chassis. Put a longer chassis on it without changing something else (gear ratio for example) and you will shorten the lifespan of the chassis, including the engine.
