berreez's avatar
berreez
DP vs Gas on Pulling
Help me understand something. If a DP has 300hp and a 6 speed transmission will it out pull a Gas A with 362hp and a 5 speed tranny if both were pulling the same amount of weight?
I asked this because I just attended the Kansas City RV show over the weekend and this was what I was told. They also said if you get a gasser much over 34’ it really struggles when towing a toad.
  • That is because it ain't about horsepower, it is about torque.
    Horsepower (to make it simple) is defined as torque times engine RPM times a conversion factor constant. Since diesels typically do not turn over anyplace as close to as fast as gassers, the torque you'll get out of a given horsepower diesel is going to be greater than what you'll get out of a gasser of the same horsepower. To see how this works, imagine an engine that puts out 100 ft lbs of torque. A gasser might do this at 6,000 rpm, and a diesel might do this at 3,000 rpm. Both will get you up a hill in the same time, but the diesel is going to be rated at 1/2 the horsepower of the gasser.
    To be sure, there are other factors in there, as pointed out above, but they START from here, and each of those others is smaller in effect than this.
  • What are the torque ratings of the two engines?
    At what rpm do they reach rated HP & Torque?
    What are the rear diff. gear ratings of the two rigs?
    What are the transmission gear ratings of the two?
    What are the weights of the two rigs?
    What size tires are on the two rigs?
    What elevation is pulling 'test' performed?
    Answer those questions and a better understanding of what each rig is capable of.
    Generic..apples to apples------diesel wins
