Bucky1320's avatar
Bucky1320
DP Weight distribution?
I have a 99 Harney on a Magnum chassis. It says by SMC on the tag, which I think I have figured out is Spartan.
It has been great, but when it is windy, the front seems to get re-aimed a lot. Kind of like the front just doesn't have enough weight on it. It is a bit worse when we have the trailer hooked up.
Here are the weights:
Front: 4660 lbs
Rear: 15,420 lbs
That is with 1/3rd tank of fuel and 1/2 tank of water. So I think I could have 700lbs or so more on the front axle full. I am way below the front capacity. I am sure I have too much air in the front tires, as I was assuming that I had more weight up there until I recently weighed.
Is this a pretty low front weight percentage? Anyone ever mount ballast up front or find room for a tank up there? My generator is in the back, so I miss out on that weight in the nose.
