wa8yxm wrote:
larry cad wrote:
(Important note: mounted on each of the heaters is a toggle "ON/OFF" switch which I switched off in preparation for removal.)
Got my information for the blower motor and went into the coach to do some cleaning, etc. and it got warm in there so I turned on an A/C at the thermostat.
Guess what? No A/C. Hmmmm. Went to the back of the coach and turned on the rear A/C. No A/C!!
First that switch is called a Circuit Breaker on the Furnace wiring diagram.
Second it supplies not only power to the Furnace. but to the THERMOSTAT as well. Turn it off and nothing HEVAC works. (Save the dash parts)
IF you actually knew what your talking about. There are 2 versions. Older had only a Circuit breaker. newer versions have both the ON/OFF switch AND a Circuit breaker. Some have the combo On/Off-Circuit breaker. Doug
