bobndot
Sep 16, 2018Explorer III
Find the location of your water tank. It might be under the bed , they are usually supported by the floor of the MH to support its weight. Follow the line down to a low point and see where it goes where you would have access to it.
Sometimes the valve is located at the tank and you can turn it from the inside.
If your fridge has a panel below it, try to remove 4 screws holding it in place and see what's behind that panel . I had low point drains there and they drained my tank too.
Sometimes the valve is behind a removable access panel inside one of the exterior baggage compartments .
Try the compartment closest to the water tank first.
** On some units that valve is also a low point drain for the H/C lines as well. If you see 'low point drains' and it takes forever to drain those lines, then you are draining the freshwater tank as well.
Look below the gravity water fill twist-off cap if you have one (that's a common area as well)
38,782 PostsLatest Activity: Aug 31, 2026
