Hi everyone, Is it necessary to drain the hot water tank when the MH is sitting for several months between trips? I live in the SW so freezing temps are not a problem. Thanks, Bill
You don't drain your hot water heater at home when you leave for a few weeks or month do you? The same goes for your RV hot water heater. Oh by the way it's a cold water heater. It probably is best to not drain it because if it's full and oxygen will not get in and cause parts to rust.
