ezgoinExplorerNov 19, 2020Draining hot water tankHi everyone, Is it necessary to drain the hot water tank when the MH is sitting for several months between trips? I live in the SW so freezing temps are not a problem. Thanks, BillShow More
dougrainerNomadNov 19, 2020You drain to keep the water and inner tank lining from getting the dreadful sulpher(rotting egg) smell. Doug
Related ContentGrey water tank won't drain completelyWater tank won't fillWater pump?Why no hot water?House battery drain
