Hi everyone, Is it necessary to drain the hot water tank when the MH is sitting for several months between trips? I live in the SW so freezing temps are not a problem. Thanks, Bill
I flushed mine several times and used vinegar on it when I bought it. I use a three filter system on it and have only drained it twice in the last seven years and that was when I winterized it while up north.
As stated above, when was last time you drained your home water heater?
If you're winterizing it, once a year is more than enough,
