Biggyniner
Mar 20, 2017Explorer
Dreaded 460 Exhaust Manifold Leak
Well I have the dreaded "tap tap tap" noise that pretty much guarantees an exhaust leak. More or less making this post to vent and to get tips from anyone who has done this before... At least the noise pretty much goes away when warm...
So far my plan is:
-Soak the studs for a few days with penetrant oil.
-By some miracle, if the engine Gods allow it, I will then attempt to remove the manifolds without busting the studs.
-I will inspect them/hone them and if any cracking is found I will replace them
-When I re-assemble I will use a high performance copper gasket. This will be very unlikely to deteriorate and will expand/contract better than the cheaper gaskets. Probably these ones
Did I miss anything? Any other advice? Sigh... I really dread this job, there is hardly any room to work and I have a trip to Northern California planned for the first weekend in May... :(
So far my plan is:
