Hello, I have water Dripping from my LR AC around the cold air exhaust area that even drips when turned off and running the BR AC. I have ensured that the drain hoses are cleared. I even disconnect ...
First thing to check if your A/C is leaking inside the coach is your inside filters. If they are clogged, your fins will ice up and water will leak inside. Remove the filters and clean/replace them. Run your A/C on FAN ONLY for about 15-20 minutes and your issue will go away...Dennis
