- j-dExplorer IIGood Deal!
Driveline Angle!
Often Overlooked... - dejaroda__ExplorerOkay here is the low-down on the 2010 Coachman Freelander's vibration.
After balancing the front end,the vibration was still there.
Sent the drive shaft to another shop to check balance and it was found to be okay.
Rear end took 30 shims to bring in line with the drive shaft. Vibration is now gone. YAY!
After a month it is finally fixed and it is all covered by the warranty we have. YAY again!!!
Thank you all for your hints and suggestions! - carz57rExplorerDid you get the problem fixed?? What was wrong?
- pauldubExplorerIt might be worth having the wheels/tires Road Force balanced.
- Cousin_Eddie93ExplorerDon't no if this has any merit as it involves a completely different vehicle but the problem sounds identical to my DW's Honda Odyssey. The dealer was stump and dumbfounded, they even replaced the mini vans little trans axle and this only worsened the vibration. We were about to apply for NJ lemon law as the thing was in the shop at least 6 times and then we get this recall notice in mail for our model year Odyssey, 2007 at the time, the recall for a shuddering transmission issue, we promptly brought in and they fixed it in 15 minutes. The vibration was completely gone. Apparently the issue involved a computerized setting that regulated the trans axle clutching.
Not saying this is anything remote to your issue but perhaps the problem may lie in the tranny. - jjbyasExplorerThank you all very much for all the replies. I just picked it up. They tried shimming the carrier bearing down or up and that did not fix it. They took the shims out and sent the driveshaft out to be balanced. It is just as bad if not worse than when it was dropped off. I am pretty upset as the motorhome was purchased new a few months ago. It sat at the rv dealership for 5 weeks. It appears will be paying out of pocket to have the commercial GM dealer fix it.
A word of advice to new buyers....... test drive before you buy to include freeway speeds. - HealeymanExplorerI have a Freelander 28QB that should be similar to the OPs unit, but mine is on a Chevy chassis so I probably cannot help.
That said, before we got this Freelander, we had a 22' 4-Winds also on a Chevy chassis.
When we developed a highway vibration, I had the tires rotated and balanced several times. Long story short, the vibration ended up being a bad drivers side front shock, as evidenced by leak marks. Even though the tires were VERY well balanced, the LF still bounced at highway speeds.
I put new Bilsteins on and that fixed it.
Tim - j-dExplorer IIGood point about angle. I was thinking of changing angle with spacers on the spring at the seat. There's a thread about a new Chevy sitting high in the rear. Wonder if it's throwing driveline angle off... So...
OP - Does your coach sit level on level ground? Or is the rear high or low? - tbossExploreryou can substantially change the degree angle by simply lengthening the spring shackles on one end of the springs
- j-dExplorer IIThe Driveline Angle idea is that the Driveshaft should face the face of the Differential {and I suppose the Center Bearing(s) and rear of Transmission} "Straight On." The concept is that the typical U-Joint speeds up and slows down as it rotates, UNLESS it's Straight On. That doesn't matter when the grocer's stock boy cranks the store awning up and down morning and night, but it does matter in a vehicle. That is why cars went to "CV" joints, the term being "Constant Velocity," to smooth thing out.
We had an OP who had this problem on a Ford-based C. I sent him some pix indicating that our differential was cocked upward to face the back end of the driveshaft straight on. I believe he went on to have a shop change the alignment of the rear axle.
I'm pretty sure that's Chevy meant by Driveline Angle, but there's another factor we should remember. A pieced shaft like we have is NOT supposed to be in a straight line front-to-rear as seen from above. It IS supposed to have a little zigzag in it. This would be seen by draping strings, weighted on both ends, over the shaft right at the "joints" {transmission, center bearing(s) and axle} then looking lengthwise along the shaft. The strings should NOT be in a perfect line. That said I don't know how much offset there should be.
38,773 PostsLatest Activity: Apr 24, 2026
