Marv_Hoag
Jul 29, 2014Explorer
Can't find the circuit breaker where the manual says it should be. Need help locating breaker location.
Update - found the circuit breaker, not the problem. Leaning towards the motor. Have absolutely no idea where to get a motor, and don't feel like buying one and finding out that's not the problem. Time for professional help!
Last update - problem solved.
After checking circuit breakers OK could not figure why no power at input harness to chair. Had a dark blue wire and a black w white stripe wire going into harness for power (no power). Peeled shielding and upholstery cover back where it came through floor. Lo and behold a dark blue and white wire coming in. Knew there had to be a connection somewhere in the shielded section. Sure enough one of the connectors had pulled apart in the middle of the run. Hooked everything back together taped it all up and problem solved. Love it when a plan comes together.
38,705 PostsLatest Activity: Jan 26, 2025
