JimM68
Nov 17, 2014Explorer
Go to the shows, dealers, and generally sit in as many motorhomes as you can. You'd eventually come up with a list of those that fit, and those that might fit with a little work, and those that will never fit.
Most motorhomes are built on the same few chassis.
And many of the non-chassis items can be moved around.
Just this past week, I relocated 5 switched in my Monaco DP, putting things I never used, such as the pedal in/out, far away, while things I did use, such as ICC flash and fog lights, moved to right under my left hand.
The ones I did just moved.
I've 2 empty slots way up to the left of the steering wheel, but the ones I needed had enough wire to go where I wanted then to go.
The 2 missing ones are traction control off and cruise cancel, who cares really? I'd never want to turn off the ATC, and cruise off or decel gets it done for cruise cancel...
38,780 PostsLatest Activity: Nov 24, 2017
