BFL13
Nov 12, 2018Explorer II
Our truck is 22 ft, with the 11ft camper on it was 25 ft, and our C is 28.5 ft.
Just the truck can be an issue for parking at the mall, etc. Have to really figure out your escape route, and can't even get in a lot of spots. With the camper on it even worse being longer and wider too.
The 28ft C is not any different. It seems like some clown will park right in front so you can't escape especially at gas stations that also have a store.
At Walmart, you just have to park on the back 40 like the other Rvs and bigger trucks do, so you can get out of there.
A longer C will swing its tail wider than a short one, so you have that to keep aware of, but a 25 does that. Since you are used to pulling a trailer, you will drive the C something the same way, going farther out and then cutting around tighter on turns.
38,782 PostsLatest Activity: Nov 09, 2020
