This is what we do for cold boondocking 2 to 3 days only after that run the generator to recharge the battery and have more time.
1 we have kerosen lamps, the ones that get shot in the western movies, light and heat.
2 we also cook on the stove, spaghetti and use the oven for dinner, x-mass simple dinners pre prepaired.
3 limit the amount of water usage, also have an accumulator for water pump saves battery
4 have a small opening on the window of the galley need ventilation while kerosen lamps are lit, do not use roof vent heat loss is faster
5 do not turn thermostat on heater above 68 during day and 60 for sleeping
6 have an outside and inside thermometer, can see both at the same time
7 limit the opening and closing of door going in and out
8 we have front windshield cover and hanging curtain inside, can feel temp diff from window to cabin on both spaces
9 have warm blankets to wrap arround when sitting
10 we lower thermostat at night to 60
11 we have a minus 40 double sleeping bag
12 snugle up with wife, buddy warmth!
13 only turn heater in morning to brake the chill
14 boughht carpet runners, our floor is wood laminate
I found that the biggest source of heat loss is at the entrance door, not even more foam insulation on the oppening helps, those doors are not that good.
We only have one 12v deep discharge gel cell marine battery for the cabin, the whole idea is in conserving the power to run the heater fan when needed and use alernate sources of light, led lamps were not available when we purchased our unit, latter they were a bit pricy so I only installed four, one in the head, one for wife to read, one in the galley and one out side, I can read with my kerosen lamp, and no tv or radio or music from CDs, some times we do not even see the park rangers at all, we mail the payment to the office, we found out that some people steel the payments from the collection boxes.
navegator
