In addition to the above info, one can add insulation to retain heat and thus run the furnace less. We have insulated window covers that snap over all the windows and a cab curtain that completely isolated the cab walls from the house (truck cab insulation sucks).
We also converted to LED lighting.
I have a multi stage power converter which charges faster than a single stage converter.
I have two AGM deep cycle batteries which can accept a charge faster than flooded batteries.
First thing in the morning I crank up a generator and start charging. I also may crank up again at dinner time depending on how the batteries are doing.
I use a Buddy Heater while we are awake.
We turn down the heat at night.
I drink single malt Scotch. Wife likes Irish.
Here is where you can see our insulation setup on two RVs we did.
