I own a 2005 38' diesel pusher. I plan to dry camp using my generator during the day and battery power at night. I have two deep cycle house batteries. My question is how many hours should the batter...
If you plan to do this on a regular basis, change out your lights to LED's. Unless your coach is wired differently than every other coach I have seen, you will NOT be able to power your AC with your inverter/batteries. If you could, you would probably be talking "minutes" for your battery life. Same goes for electric heaters. Some coaches will allow the microwave to be used off of your batteries, but with my coach, even the four batteries do not last too long when using the microwave.
