othertonka
Jun 13, 2013Explorer
It sounds like you are using the propane switch and the 120 AC switch at the same time, and when the propane side fails to light the "Failed to light (RED) comes on indicating that it indeed failed to light. `The water heater should continue to heat on 120 AC electric even if the indicator light is ON. A lot of people do run their heater on both for a quicker heat up. Is that what you areding when this happens?
