dougrainer
Jun 14, 2013Nomad
Diplomat Don wrote:
The DSI fault light only pertains to the gas side of the water heater. If it's coming on when the gas is off and you're using 120 AC, then you have a weird issue where something is shorting out between the two systems.
IF the Electric side fails to shut OFF (defective tstat) and the ECO trips the DSI fault light will come on. IF you have the unit on LP AND 120 at the same time and the LP side fails to light, the DSI fault light will NOT come on. Doug
