dougrainer
Jun 14, 2013Nomad
topher80 wrote:
Thank you all for your comments. The gas switch is off, so it must be a weird thing...cause with the gas switch off it should not be faulting, right.
Guess I won't be worried about it provided I have hot water on shore power.
READ my post again. Your tstat is bad and the ECO is tripping causing the DSI fault light. THAT is the reason for your scalding hot water. The ECO trips at 180 degrees instead of the tstat tripping at the normal 130/40 degrees. Doug
