The reason the Fault light is lit while on electric is because the ECO (high temp T-stat) has OPENED.
That is why water temp is very HOT
Normal t-stat is not opening shutting down water heater and the ECO is having to shut it down.
You have a Atwood
Normal t-stat pre-set for 140*F and ECO is pre-set for 180*F
ECO Opens causing Fault light and it auto resets when temp drops below 150*F
The normal t-stat may be loose and therefore not sensing tank temp properly. Has to be TIGHT against tank wall and tank wall needs to be clean surface
Just buy new set...Normal & ECO come as set on a card.
You can just replace normal and keep the extra ECO as spare.
(If it was a Suburban and the High temp t-stat had OPENED ----you would have to manually reset it before it would reheat)
Fault Light:
IF propane fails to light off and prove main flame
ECO Opens whether on gas or electric
