brianseay1
Aug 23, 2013Explorer
DSI fault
I keep getting a DSI fault light coming on when using my waterheater. It will heat up the water just fine on electric, gas or both. I have put the switch on electric only and get the fault, I can put ...
SacsTC wrote:brianseay1 wrote:
This problem has resurfaced again. I just put in a new control board two weeks ago. This is the first time out and it came back on after the water heater had been on for awhile. Still have hot water with both switches on (elec. & gas). It is an Atwood unit. What else can I check ?
Question??? Did you actually go outside and physically check to see if the heater is working on propane??
If I'm not mistaken, that light comes on only when the propane side is mal-functioning. It tries to light the flame several times and then quits, which is when the light comes on. The heater will still work on electric which explains why you have hot water.
