joexsmoot
Nov 14, 2016Explorer
thanks gordon and bordercollie for the replys
Gordon - That's true I didn't think about that. I have a automatic transfer switch going to a 110v fuse panel currently powered by either the inverter or hook up power. I can just as easily take the 30A plug for docking and plug into a generator. for while I'm on the road / camping somewhere without power.
Bordercollie - From the bit of research ive done, if I do it myself it'll be in the ballpark of $800 and roughly 18 hours of labor, assuming Murphy is feeling nice. (Murphy's Law). You have to replace pretty much everything except the tubing and the fan/heater core assembly, although its recommended to disassemble and clean out because of the oils in r12 vs r134a, but at that point id pick up the tubing anyways.
If I have a place do the full retrofit kit, I found one that offered a flat rate $2000.
I guess I could find all used parts from a 96+ e350 that with some modifications, I could make work. That would bring the cost down to 300-400 if I found some good deals.
38,782 PostsLatest Activity: Aug 23, 2026
