Bird_Freak
Nov 14, 2016Explorer II
joexsmoot wrote:Go to local parts store and tell them you want a conversion kit to R134, Cheap, This will be the ports you need to convert lines to take 134 gauges. You will need a flush kit and may have to break lines loose and replace o rings with the green ones due to age. You also need to change the dryer and oil in compressor if you don't change compressor. Check Autozone or O riellys. They can put you on track for cost to change. Also check Rockauto.com for best prices.
Bird - Would you mind to point me in the right direction if you have any websites? Any I've found say to replace pretty much everything, or r12 for outrageous prices.
Thanks! I'll start looking some more then i guess.
If only you were closer to NJ. I'd bring it to you!
38,782 PostsLatest Activity: Sep 10, 2026
