rookie_rv
Apr 27, 2015Explorer
Dual Antenna
Rookie Rver :C here! Do you know if there is a such thing as a "dual tv/satellite antenna" for motorhome? I am looking for one antenna that will allow for local channels and/or also can be used fo...
YC 1 wrote:bukzin wrote:YC 1 wrote:
Direct tv has a box that will combine your locals too but you still need a separate antenna.
Sounds good. What is that model number and approx. cost?
Thx
over the air receiver
This plugs into your DVR via a usb cable. Your AC cord is plugged into the new box and then the new box is plugged into AC. The DVR recognizes the unit and will scan for over the air channels when you do a very simple setup. Signal strength is available as well as downloading channels via your zip code. You can delete unwanted channels. It will record them too. If a storm blocks your satellite signal you still have the over the air signals.
