bigwheelsturnin
Mar 10, 2014Explorer
Dale.Traveling wrote:
I wasn't sure if there would be a clearance issue between the tow bar and the bike rack and I didn't want to find out the hard way with a handle bar poking thru the rear cap. Preempted modification to a $50 eBay bike rack.
There's a couple of different styles on duel receivers that should work for what you want. The Roadmaster is pretty shout and would make a good boat anchor. Other's I've seen are a bit lighter on the second receiver and are intended to bike racks or other none towing applications. The other end of the tow bar is connected to a 98 Honda Accord which sits a bit lower than the coach hitch. If I ever decide to use my CRV as a dingy I'll probably dispense with the dual receiver and hang the bikes off the back of it.
thanks for info we plan to set cargo rack in top one for items used little like dump tank receiver on mh is high off the ground what i need to check now is tow bar mine lifts straight up and locks in position and then you drop to one side when not in use may just have to remove it when we are set up
