S-n-L
Apr 26, 2014Explorer
Dual tow hitch extension
Hello everyone,
I need a dual hitch reviewer so I can use a bike rack while towing my toad. I need a straight extension with the second hitch mounted on top.
I have seen a bunch of these online however the problem is the max tow capacity is 4,000 lbs. Roadmaster has a 6,000 lb version but only has a drop hitch, not a straight for the primary hitch.
Anyone know if any such product with a higher tow capacity?
One other thought but not sure if this could work. If I purchase a straight extension from Roadmast (6,000 lb) and have an additional hitch welded on by a weld shop. Do you think this could work? Not sure if welding lowers the tow capacity.
Thanks for all your advice,
Stuart
Stuart
