TwoPines
Nov 18, 2015Explorer
Dual Rear Tire Valve Stems?
Looking for suggestions about options for adding air valve stem adapters on dual rear wheels? Bought a Jayco E-350 Class C with 225/75 16" tires a few months back and while winterizing noticed that the valve stems on the dual rear wheels are located between the two tires. So, unless I dismount the outer tire, I can't check tire pressure on either tire, nor can I add air if needed. Are there types of adapters preferred or are there replacement stems or what options are there? I would rather have an idea about what I need before going to the tire shop for a fix.
Thanks in advance.
Thanks in advance.
