willald
Aug 21, 2013Explorer II
...I can recommend the Heavy Duty Trucks - Valve Stem Extension Stabilizer Kits that Alcoa Wheels sells for their aluminum wheels. You can use them on most wheels that are on motorhomes.
..Those are valve extension stabilizers. If you're using a valve extension, you still are adding a potential failure point, where the extension screws onto the valve stem.
With the Dually Valves, you get a complete valve stem replacements for both inners and outers as well as a rubber piece to hold it in place. Not extensions. Much better solution, IMO, and less prone to leaking.
wny_pat wrote:
I can not recommend the Crossfire system. Company I retired from tried them and decided they were not adequate for their regional trucking operation. My son had the on his car hauling rig and had one tire blow out and it took the other tire with it. Crossfire didn't help at all.
Pat, this is almost exactly what you said in my other thread, about why you did not recommend dually valves. I and several others asked you for clarification, but you never responded in that thread.
I think your note here clears up the misunderstanding, and the mystery from the previous thread: You mis-read what we were talking about in that thread, and thought we were talking about Crossfire, not Dually Valves. Soooo, your son, and the company you retired from had issues with Crossfire, NOT Dually Valves.
Glad we finally got that straightened out. :)
Will
